Hey, I am intending to get the MD2S 5.0 kit, but I am puzzled by the fact that are the XB35 D2S ballasts worth the extra money? I have a pair of DLT F3T Fast Bright ballasts already, so I am wondering will they outperform the XB35 ballasts (not to mention durability and other quality related features)?
The F3T input wattage is about 58 watts (haven't managed to measure the output wattage), so I am a bit worried if the D2S bulbs will be running on too high wattage to cause harm to the projectors reflector bowls, either through increased heat or the emitted UV radiation. This also quite obviously will shorten the lifespan of the bulbs.
If I happen to use the F3T ballasts, will a regular D2S adapter do the job? I am intending to power the ballasts from the original low beam wiring using the spade connectors.
