Backround image in text field
  • Backround image in text field
    While it looks cool, I can't see what I'm typing! Can you fix please?
    While it looks cool, I can't see what I'm typing. Can you remove it?
      so screwed up the edit/approve of the posts... but yeah i get the same issue.
      I thought it was just me for awhile and some messed up cookies
      Write Something....../
        Just click that first button on the left of the bar at the top of the reply box, the "source" button
          God damn that picture is hideous
            Had that background image issue too, clicked the "source" button like Goldy instructed. Quote isn't working though.
              Yeah I can't edit posts because I'm like an allowed spambot or something haha.
              Thanks for the source suggestion, works decently enough.
                Lifesaver. Thank you! I wish there was a way to permanently leave that on though. And like suggested above, I can't use quote when source is clicked.
                  If you hit "quote" first, and THEN hit the <> source button, it works fine
                    Good call. Thank you!
                      Please disable this background...it's really annoying
                        I also noticed with the background image off and try adding a smiley it sends you to the main forum screen. But if you're composing a post with the background image on, it works find and does not send you to the main screen.
                          yeah, you basically can only type the message with the formatting off, and if you want to do anything else like add images, you have to do it switching the formatting back on.
