This isnt an LED light bar, but more of an LED light. It can be used as an auxiliary high beam, a reverse light, or anything you can think of. Its compact, round, fog light esque, and decently powerful.
Details
This $15 LED light features nine 3W LEDs totaling 27W of total power with 60 degree flood optics. The light has an IP67 water resistance rating.
The optics on this light are interesting. Instead of just a reflector bowl, theres a small center mounted lens that likely focuses the light slightly better.
The light is also offered in a square model for around the same price.
Link: https://amzn.com/B00I95VIYU
Build quality
As most off road LED lights on the market these days, the build quality is fantastic. The metal is great, the powder coating is of very high quality, there are no shakes or rattles, and there is no flex. The lens is surprisingly sturdy as well.
My only complaints are the cable and the bracket. The cable is of good quality, with thick yet flexible insulation, but the ends coming out of the sheath are short and just bare contacts. Some spade connectors would have been nice at the minimum, though a 9006 connector would have been ideal (and cheap).
The brackets for the bars are just a piece of metal with a bolt and a nut. Not particularly high quality and need to be torqued down hard to stay still. There are no ribs to keep it from moving after being tightened down. Its strange because the body of the light has the ribs on it, almost like the brackets were an afterthought while the original plan was for large light bar style brackets.
Output
The output of this LED light is quite good for the size, price, and considering it only has flood optics. The 60 degree flood optics are more focused than many other flood beam light bars, making for better distance. However, the light spread is still fairly even and not too concentrated in the center. Its a pretty good compromise between flood and spot, beating out many flood bars while having more than 20 feet of distance.
As you can imagine, the distance isnt that great considering its a flood light. But its pretty nice.
The emitters put out a cool white light, around 6000K. Theres some blue in the center, but not much. The edges of the output have a yellow tinge due to the optics.
At about 25 feet. Dark:
Mini 6 LED light bar:
ANNT 27W:
ANNT 120W light bar:
At 150 feet. Dark:
ANNT 27W:
Now at about 45 feet on a white wall. Dark:
ANNT 27W:
2x ANNT 27W:
Underexposed now. ANNT 27W:
2x ANNT 27W:
Dark:
ANNT 27W:
Uses
Now, these kinds of lights obviously shouldnt be used extensively on the road. On empty back roads sure, but theyre technically off road lights. These are ideal for an off road vehicle, or for private property.
I live in a private neighborhood with extremely poor lighting, so I often have to use auxiliary lighting to safely get around (especially in reverse).
But my main thought for these lights is garage work lights. Theyre lightweight, small, and can be mounted to a small stand. I use a Snap-On LED work light, but one of these can work just as well for a fraction of the price. Youll have to get a bit creative with mounting and power sources, but I already have a plan for that. I bought a bunch of EC5 connections and will be connecting various lights to a lithium jump starter for portable power. Whether its for working or camping, thats a pretty awesome use for any LED light.
Conclusion
For $15 a piece, the performance is quite good and the light itself is very affordable. I definitely recommend picking one or two up if you need them.
These lights can be found for half the price on eBay without branding if you want to save money. Warranty is up in the air with this option, but youll save some money. Whether quick shipping from Amazon and a potentially better warranty is worth the price is up to you.
Details
Build quality
Output
ANNT 27W:
At 150 feet. Dark:
ANNT 27W:
ANNT 27W:
2x ANNT 27W:
2x ANNT 27W:
Dark:
ANNT 27W:
Uses
Conclusion
