Bi LED mazda3 2017
  • Bi LED mazda3 2017
    Hi everyone, i just have got new bi LED from Mazda3 MC 2017 but don’t know how to light it up😅
    It only 4 wires connector
    Blue is ground
    Green/white is high beam
    What are purple and white for?
    PS. When i try touching white and fan under heatsink working but no light!!!
    Thanks in advance.
    Sorry guys- my bad 😜
    Nothing wrong with it.
    My battery is weak.
      Looks like a Stanley biled. I wonder if it's the same as the new Toyota RAV4?
      Can you post more photos of the projector itself?
        I figured the RAV4 would use the Koito Bi-LED like the Lexuses and other Toyota products.
          It doesn't. It uses a Stanley biled.
            I bet it's similar to the new Impreza Bi-LED
              Is it same as Mazda 6 projectors? I was impressed with the light distribution of them (might've been xenon, I didn't get a very good look at it).
                nice bi-led... i wish it was cheaper to source nowadays
                  Hy guys.
                  My first post here.
                  Sorry for raising this from the grave but can someone please tell me about the wiring on the connector of this driver.
                    Anyone?
                      Got the damn thing to light up and throw down the high beam shield. Thnks to evo77's answer on FB
                        One more question about this projector.
                        How well is the lens protected against the UV coming from the sun light? I'm retrofitting a pair into some subaru impreza headlights and the projector lens sits quite a bit outside the shroud and I'm worried about the lens getting yellowed over time.
                        I'm planning to get some UV protection film on the outside of the headlights but still...
                          The lens is most likely polycarbonate which has a low resistance to UV exposure UNLESS the resin contains UV stabilizers.
                          Unfortunately only Stanley can answer this question for sure.
