WARNING: USE THE FOLLOWING INFORMATION AT YOUR DISCRETION, IT IS PROVIDED AS A GUIDE ONLY AND MAY NOT BE OF EXACT TOLERANCES. MAKE YOUR MEASUREMENTS CAREFULLY. AUTHOR, THIS SITE, OWNERS, MODERATORS AND MEMBERS WILL NOT BE RESPONSIBLE FOR ANY DISCREPANCIES OR ANY INCOMPATABILITY
PLEASE READ: Length was measured with a D2S in there and is measured to the end of the bulb. Diameter was measured for shroud fitting purposes and is a measure right on the edge, around the glass lens housing.
Hella 2nd Gen Bi-Xenon (aka E55):
Diameter = 79.80mm
Height = 96.95mm
Width = 106.15mm
Length = 163.35mm
Length(seat of the lens to possible mounting holes) = 58.80mm
Length(possible mounting holes to end of bulb) = 83.90mm
Width(between top mounting holes) = 77.25mm
Width(between bottom mounting holes) = 93.25mm
Height(between mounting holes) = 58.90mm
Stanley Bi-Xenon (aka TL):
Diameter = 80.25mm
Height = 95.95mm
Height(with solenoid) = 117.15mm
Width = 111.60mm
Length = 171.85mm
Length(seat of the lens to mounting holes) = 56.90mm
Length(seat of the lens to end of solenoid) = 89.25mm
Length(mounting holes to end of bulb) = 95.80mm
Width(between top mounting holes) = 82.55mm
Width(between bottom mounting holes) = 90.85mm
Height(between mounting holes) = 71.40mm
Bosch Bi-Xenon (aka E46):
Diameter = 78.30mm
Height = 84.10mm
Width = 105.00mm
Length = 166.95mm
Length(seat of the lens to mounting holes) = 66.65mm
Length(mounting holes to end of bulb) = 80.70mm
Width(between top mounting holes) = 82.00mm
Width(between bottom mounting holes) = 95.10mm
Height(between mounting holes) = 62.10mm
Valeo Bi-Xenon D1S:
Diameter = 82.55mm
Height = 96.00mm
Width = 106.20mm
Solenoid(sticks out by) = 9.40mm
Solenoid Length(from mounting holes) = 69.05
Length = 156.20mm
Length(seat of the lens to mounting holes) = 49.45mm
Length(mounting holes to end of bulb w/D2S) = 84.25mm
Width(between top mounting holes) = 72.20mm
Width(between bottom mounting holes) = 70.95mm
Height(between mounting holes) = 78.20mm
Infinity FX35/45 Bi-Xenon (aka FX):
Diameter = 69.20mm
Height = 105.10mm
Width = 111.80mm
Length = 150.70mm
Length(seat of the lens to mounting holes) = 54.60mm
Length(mounting holes to end of bulb) = 72.10mm
Mounting hole distances are not measured beacuse most people
would make their own and cut-off stock brackets.
Land Rover LR3 Bi-Xenon (aka LR3):
Diameter = 78.30mm
Height = 95.30mm
Height Trimmed = 88.50mm
Width = 126.30mm
Width Trimmed = 121.70mm
Length Total = 141.75mm
Length(seat of the lens to mounting holes) = 45.50mm
Length(mounting holes to end of bulb w/D2S) = 96.25mm
Width(between top/bottom mounting holes) = 63.20mm
Height(between mounting holes) = 76.80mm
Hella Low Beam (from pre-2002 Audi A6):
Diameter = 71.90mm
Height = 103.65mm
Width = 110.55mm
Length = 159.00mm
Length(seat of the lens to mounting holes) = 55.40mm
Length(mounting holes to end of bulb) = 84.45mm
Width(between top mounting holes) = 67.85mm
Width(between bottom mounting holes) = 82.35mm
Height(between mounting holes) = 87.95mm
Audi A4 Valeo DOT D2S Low Beam:
Values are approximate
Height = 85.00mm
Width = 100.00mm
Length = 150.00mm
Length(seat of the lens to mounting holes) = 60.00mm
Width(between mounting holes) = 60.00mm
Height(between mounting holes) = 72.00mm
Thank you LiquidKernel for Valeo measurements
Mitsubishi Lancer Evo8 Low Beam:
Diameter = 85.10mm
Height = 86.00mm
Width = 109.50mm
Length = 171.40mm
Length(seat of the lens to mounting holes) = 61.75mm
Length(mounting holes to end of bulb) = 77.30mm
Width(between mounting holes) = 98.15mm
Height(between mounting holes) = 28.35mm
Mazda 3 Low Beam (Stanley):
Diameter = 85.10mm
Height = 98.50mm
Width = 116.50mm
Length = 167.00mm
Length(seat of the lens to mounting holes) = 53.00mm
Length(mounting holes to end of bulb) = 87.70mm
Width(between mounting holes) = 97.85mm
Height(between mounting holes) = 68.50mm
High beam bracket would be cut-off on this projector, comes integrated OEM.
Lexus RX330 Low Beam (Non-AFS, w/Subaru Legacy Shield):
Diameter = 77.10mm
Height(with Shield) = 109.50mm
Height Bowl = 96.70mm
Width Bowl = 106.50mm
Length = 139.20mm
Length(seat of the lens to mounting holes) = 48.60mm
Length(mounting holes to end of bulb) = 90.60mm
Width(between top mounting holes) = 33.75mm
Width(between bottom mounting holes) = 40.50mm
Height(between mounting holes) = 98.80mm
This projector usually comes with a cut-off shield that has OEM mounting brackets integrated. Most would usually cut these off and make their own holes for mounting. Subaru Legacy Halogen projector is almost idnetical to this Xenon projector. We used cut-off shield from the Legacy projector as it is smaller and has mounting holes built-in. All measurements are to reflect shield replacement. Height and width measurements are also given for an actual Xenon reflective bowl.
Acura TSX Low Beam (Stanley):
Diameter = 71.05mm
Height = 85.30mm
Width = 120.80mm
Length = 156.45mm
Length(seat of the lens to mounting holes) = 42.00mm
Length(mounting holes to end of bulb) = 96.95mm
Width(between top mounting holes) = 100.45mm
Width(between bottom mounting holes) = 103.45mm
Height(between mounting holes) = 41.50mm
Honda S2000 Low Beam (Koito):
Diameter = 71.70mm
Height = 105.60mm
Width Trimmed = 113.50mm
Length = 135.30mm
Length(seat of the lens to mounting holes) = 41.40mm
Length(mounting holes to end of bulb) = 93.90mm
would make their own and cut-off stock high beam bracket, width is measured as trimmed.
Lexus SC430 Low Beam (Koito):
Diameter = 71.70mm
Height = 100.30mm
Width = 130.00mm
Width Trimmed = 125.30mm
Length = 138.30mm
Length(seat of the lens to mounting holes) = 43.90mm
Length(mounting holes to end of bulb) = 94.40mm
would make their own and cut-off stock mounting brackets, width is measured as trimmed because it could be trimmed a bit.
Lexus LS430 Super Wide Low Beam (Stanley):
Measurements for this projector are provided as "naked" - shroud removed, OEM mounting bracket removed, supplemental reflector was included in measurements. Also, assumed some "fat" (eg.: AFS spindles) would be trimmed. Where it says "trimmed", this is only an assumptive place where it was deemed best to trim without too much sacrifice. Some people will choose to trim more or not to use the whole or most of the shroud that gives this projector most of it's bulk. Please remeber that this is a very large projector/shroud combination.
Diameter = not measured as this projector comes with it's own shroud
Height = 117.05mm
Max Width = 134.32mm
Trimmed Width = 125.80mm
Width Bottom Reflector = 124.10mm
Length = 154.75mm
Length(tip of the lens to possible mounting holes) = 55.95mm
Length(possible mounting holes to end of bulb) = 98.80mm
Lexus LS430 shroud measurements:
Max Height = 143.62mm
Trimmed Height = 131.70mm
Max Width = 173.15mm
Trimmed Width = 154.30mm
Diameter = 79.80mm
Height = 96.95mm
Width = 106.15mm
Length = 163.35mm
Diameter = 80.25mm
Height = 95.95mm
Width = 111.60mm
Length = 171.85mm
Diameter = 78.30mm
Height = 84.10mm
Width = 105.00mm
Length = 166.95mm
Valeo Bi-Xenon D1S:
Diameter = 82.55mm
Height = 96.00mm
Width = 106.20mm
Length = 156.20mm
Diameter = 69.20mm
Height = 105.10mm
Width = 111.80mm
Length = 150.70mm
Diameter = 78.30mm
Height = 95.30mm
Width = 126.30mm
Diameter = 71.90mm
Height = 103.65mm
Width = 110.55mm
Length = 159.00mm
Height = 85.00mm
Width = 100.00mm
Length = 150.00mm
Diameter = 85.10mm
Height = 86.00mm
Width = 109.50mm
Length = 171.40mm
Diameter = 85.10mm
Height = 98.50mm
Width = 116.50mm
Length = 167.00mm
Diameter = 77.10mm
Length = 139.20mm
Diameter = 71.05mm
Height = 85.30mm
Width = 120.80mm
Length = 156.45mm
Diameter = 71.70mm
Height = 105.60mm
Length = 135.30mm
Diameter = 71.70mm
Height = 100.30mm
Width = 130.00mm
Length = 138.30mm
Height = 117.05mm
Length = 154.75mm
