DISCLAMER:
Try this modification at your own risk. I'm not responsible for any personal injury/death, mistakes/long term effects and/or damage to property. Please be cautious, ballasts run at high voltage and can carry risk of death if altered by people. Please refrain from carrying out this modification if you are unaware of the risk involved.
Hopefully these pictures will help people modify their denso ballasts. This mod is hard because you have to work in such a small space but the results are amazing. Again, as usual, do this at your own risk. For off road use only. Enjoy!
Remove the metal screw and pry the cover off
You will need to remove the potting material to gain access to where soldering needs to be done. I have read on the forums that q-tips are good for removing denso potting material. Whatever works best for you.
(finished denso)
(close ups of area that you have to work with)
Solder the wires from the potentiometer to the resistors as shown in the pictures. Some people like to remove the resistors completely.
10k pot
