Halogen Bulbs vs HID Bulbs vs LED Bulbs And Where They Belong
Tags: None
That the only H11 led bulb you tested? Because that one blows chunks.
I've tested a few different ones and currently this one here is sitting in the wifes minivan. Double the lux. Wider beam. Few lux more glare above the cutoff.
Eklight K6
For a reflector that cutoff is kinda impressive, they're usually fuzzy and undefined. The additional glare above cutoff from the LED is probably negligible in real life, camera exposure just makes it more obvious. Is the bulb rotatable?Originally posted by HK45I don't even look to see what Eddie writes anymore. I'm too busy staring at his avatar.
It really is a great beam and I'm happy with it (except for the finicky dodge canbus system that gives faint flickering here and there). I'll be purchasing a dash cam to take some before/after night footage to illustrate the difference. The sharpness of the cutoff on the road does appear at times on a bumpy surface to mimic a projector.
The LED image above only appears to be more glareish because the beam is wider thus spilling over to the adjacent wall which is reflecting that light over. As stated the lux meter only registered a few more lux more above the cutoff. And for what its worth, when I compared my Cruze headlamp to the minivan headlamp, the Cruze registered more glare above the cutoff. Both tested with their respective halogen bulbs.
Round reflectors offer the best beams I suppose.
Originally posted by Eddie View PostFor a reflector that cutoff is kinda impressive, they're usually fuzzy and undefined. The additional glare above cutoff from the LED is probably negligible in real life, camera exposure just makes it more obvious. Is the bulb rotatable?
Originally posted by evo77 View PostThat the only H11 led bulb you tested?
Sad part is that LED bulbs that claim "4800lm" probably have half the lumens (half the bulb) shining on the reflector bowl and that other light gets trapped behind the shield. aka only 2400lm maybe that gets out past the projector.
Originally posted by rdriggett View PostGlad to see this test, hopefully we can start linking this along with my guide to end thread clutter.
That looks like a h11 low beam projector, same as in my Mazda 3. No bulb, hid led or h9 swap makes it any good.
And that is your run of the mill H11 projector. It's HID swap is RX330 Non AFS aka Maxima
