Mods, this might be sticky material.. Since I rarely post I will leave this here.. move, delete, sticky.. do whatevs..
Greetings HIDP crowd.. So back when JVX had his site up, I had the foresight to save his pages as PDF files in case he took it down for whatever reason.. Hosting bills are a pain if you don't actively use your own site.. So no offense or copyright theft meant here at all.. I think we all know how valuable his info was.. Here they are linked below for you all to view/download..
Also, a user on HIDP (I forget who so please take credit for it if you see this) posted this link to his GitHub account where he went further and created a browser based selectable comparison of many projectors.. that link is also below... it won't work in mobile browsers I think because its Java based but I could be wrong..
Happy cut-off viewing here:
http://proantagonist.github.io/Proje...0Comparison/#/
JVX PDF link below:
https://www.dropbox.com/sh/jxbx85h2g...dwzNuW61a?dl=0
File listing:
JVX PDF link below:
File listing:
- 35w vs. 50w Ballast Comparison Using Mini H1 and RX330 Projectors.pdf
- Asian-Made G1 and G3 Bixenon Projectors.pdf
- AUDI A6 HID Projector Retrofit.pdf
- Bi-xenon LR3 Oem Lens vs. STi-R Lens Comparison.pdf
- Bi-xenon Murano Oem Lens vs. STi-R Lens Comparison.pdf
- Bi-Xenon Output Comparison: TL, E55, Murano, FX, FX-R, IS, IS Hybrid, e46, LR3, MiniH1, MiniD2, S2K-.pdf
- BMW X5 HID Projector Retrofit.pdf
- Bulb Spacing Mod for Hybrid IS250 Projector.pdf
- Bulb Spacing Mod for Non-AFS RX330 Projector.pdf
- Bulb Spacing Mod for Oem FX Projector.pdf
- Bulb Spacing Mod for Replica FX Projector.pdf
- Bulb Spacing Mod for S2000 Projector.pdf
- Cadillac CTS Projector: Oem Frosted Lens vs. Clear Lens.pdf
- Custom Angel Eyes Upgrade.pdf
- Custom Angel Eyes.pdf
- Fitting non-H3 Base Bulb Into H3 Base Foglight.pdf
- FX Projector Lens Swap Using Oem, FX-R, TSX, TSX-R, E30.pdf
- HID Foglight Conversion.pdf
- HID Lowbeam Output Comparison: TSX, S2K, SC430, Q45, RX330, Murano, LR3, LS430, E39, TL, FX, E55, A4.pdf
- HID Projector Beam.pdf
- HID Projector Beams Output Comparison.pdf
- How To Shield Mod Step-by-Step.pdf
- Hybrid IS vs. Modded RX330.pdf
- Hybrid IS vs. Replica FX.pdf
- Hybrid S2000: S2K Front Half With RX330 Reflector Back.pdf
- Improving the Mini H1 Bi-Xenon Projector.pdf
- Lexus IS250 Foglight Retrofit.pdf
- Lexus IS250 Headlamp Retrofit.pdf
- Light Output Comparison: Hybrid SC430 vs. Modded RX330.pdf
- Light Output Comparison: Hybrid SC430 vs. Replica FX.pdf
- Light Output Comparison: Mini H1 vs. Oem FX with Clear Lens.pdf
- Light Output Comparison: Mini H1 vs. Oem TL with Clear Lens.pdf
- Light Output Comparison: Modded RX330 vs. Mini H1.pdf
- Light Output Comparison: Modded RX330 vs. Replica FX.pdf
- Light Output Comparison: Modded S2000 vs. Modded RX330.pdf
- Light Output Comparison: Modded S2000 vs. Modded SC430.pdf
- Light Output Comparison: Oem FX vs. Replica FX.pdf
- Light Output Comparison: Oem S2000 vs. Oem FX with FX-R Clear Lens.pdf
- Light Output Comparison: Oem S2000 vs. TL With ZKW.pdf
- Light Output Comparison: Old Bulb vs. New Bulb.pdf
- Light Output Comparison: Replica FX vs. TL With Clear Lens.pdf
- Light Output Comparison: Using Various Oem and Modded Projectors.pdf
- LS430 Lens Swap: Comparing Oem, TSX, TSX-R, E30, 300zx Lenses.pdf
- Mazda 3 Lens Swap: Oem vs. Replica Lenses Comparison.pdf
- Modded RX330 with E30 Lens and Custom Curve Shield.pdf
- Modded S2000 Projectors With Custom Shields.pdf
- Prism Shield.pdf
- Reflective to Projector Conversion.pdf
- RX330 Oem LHD Cutoff Shield vs. Custom RHD Cutoff Shield.pdf
- S2000 Lens Swap: Comparing Oem, TSX, TSX-R, and E30 Lenses.pdf
- S2000 Z-Tail + TSX Mirror Mod Beams Output.pdf
- SC430 Lens Swap: Comparing Oem, TSX, TSX-R, E30, and 300zx Lenses.pdf
- Scion tC HID Retrofit With S2000 Projector With Prism-Tail Shield Mod.pdf
- Shield Mod Step-by-Step.pdf
- TL Lens Swap: Comparing Oem, ZKW, and ZKW-R Lenses.pdf
- TSX Lens Swap: Comparing Oem, TSX-R, and E30 Lenses.pdf
- Valeo A4 Projector: Comparing Oem Flat Shield vs. Custom Curve Shield.pdf
