Clear Lens Swap Tuning + Output Comparison - Lexus RX350 / STi-R
Follow us on Facebook & Instagram ! Subscribe to our YouTube channel for pro tips and behind the scenes videos!Tags: None
- 2 likes
it has its positives and negatives
damn daniel! back at it again with the clean beams I see!
Originally posted by Mostafa United View Post
negatives ?
- 1 like
Sharp cutoffs can be rather distracting and there is very little light above the cutoff which makes it hard to see street signs and such.
- 1 like
Really, what are the negative points of clear lens swap on these rx350 projectors ?
- 1 like
Originally posted by Nuvolari
To add to what HK said the sharp transition from very bright to dark causes eye strain and makes it more difficult to see past the cutoff. In addition the fresnel lens blurs the beam pattern and makes the light under the cutoff more even and equally dispersed vs the clear lens which enhances the light and dark areas within the beam. Fresnel lenses also blurr the actual cutoff line making them appear straighter vs clear lenses which make the different heights of the cutoff more noticeable.
Quote from the IIHS
"A vehicle with excessive glare on any of the approaches can't earn a rating above marginal"Last edited by Pklemm; February 3rd, 2017, 09:12 PM.
Originally posted by Pklemm View Post
This is something I wanted to mention as I was thinking about the most recent IIHS test of the electric cars. Cars were getting poor rating for the headlights due to glare. They (IIHS) measured glare down the road at 3 feet 7 inches off the ground. Now wouldn't a clear lens solve this issue. Shaper cutoff causing less glare. The IIHS mentioned a number of times how some cars had good headlight but the glare made them poor. Seems like IIHS is hinting for a more controlled cutoff. The lux reading they measure for glare was I think 5 lux so not a ton of light but enough for their sensors to detect it and fail the headlight.
Quote from the IIHS
These things are effectively reduced with a blurred lens making the transitions more gradual and reducing color at the cutoff and adding more yellow instead of blue/purple to make it less noticeable. The yellow cutoff mixes well with the light emitted from the projector.
- 1 like
Originally posted by NuvolariThis is hard to answer because I don't really know what they mean by glare and how they determine it. Yes, a clear lens will definitely define the cutoff better and reduce light above a certain level. But once the car squats and nose dives the cutoff will rise and fall making it seem like the headlights are high-beaming since the transition from light to dark is so abrupt. This can be percieved as a form or glare. So can the colorful cutoff produced by using a clear lens. Some drivers don't like light shows while driving.
Basically what I am getting at is, would the negative effects of a clear lens for a driver have a bigger positive effects for oncoming drivers? (This is going off of the IIHS scrutinization of glare). I'd also like to see what they would say about a RX350 clear lens swap/ tuning retrofit. How would that stack up in their testing? Especially since the sharp cutoff wouldn't come into play on their test instruments (as far as the effects on the drivers eyes with a sharp cutoff)
