How To Shim A HID Bulb For Proper Alignment
This is a sticky topic.
  • NoodleFace
    Originally posted by HK45 View Post
    Also, if you would like to share your before and after shim pics, please post them. Have fun and good luck!
    This is on a buddy's elantra with a budget retrofit (MH1 6.0 and no-name ballast and bulbs)
    Passenger's side I thought needed no shimming
    Driver's side had a low hotspot
    And that's the driver's side after shimming at 12 o'clock
    I hope I did a good job and I really appreciate the detailed guide especially since I used the 7.0 in my own retrofit
  • Benz1911
    I purchased a pair of center sections and modified them like this cause i really don't like that steep cutoff.
    No bowing here.
  • Haloruler64
    The Osram trust system can be fooled. If you didn't buy from a retailer like TRS or Lightwerkz they very well may be fakes. The beam pattern should be IDENTICAL to your stock beam pattern.
  • Figs45
    I verified them with the osram trust system. If it was easier to upload pics I would show you the beam patterns etc. made a small adjustment to passenger side and got it in a little nicer. Has a cutoff similar to drivers side. Still not a huge fan of the CBB color but maybe I’m just old. Haha.
  • Haloruler64
    Then you must have installed them wrong, or bought fakes. One of the two. All OEM bulbs have the same cutoff and hotspot location, same beam pattern. Just various color temperatures and levels of brightness.
  • niZmO_Man
    Check the bulb seating again.
  • Figs45
    Changed bulbs in my 14 srt Grand Cherokee. These are osram CBB D3S. Very unhappy with them. The passenger hot spot is about 6 feet in front of the vehicle and no nice cut off. Looks like a frown on that side. Drivers side is a little better but overall prefer factory. Can the d3s be shimmed or are the “fingers” in a d3s mount bent and I need to keep bending and reinstalling till they look good? Replace with factory bulbs is my next step.
  • Haloruler64
    Seems a bit thick, but if it works, it works. Usually we use cardboard like from a cereal box, sometimes double layer it with double sided tape.
  • jomor
    Originally posted by 19wrx View Post
    I can’t seem to find the hotspot on my drivers side. How would I shim this?
    you must have the same problem as I have, the hotspot is a lot above the cutoff line and I had to move the lit bulb by hand on a dark area to find it out. I now have to move it towards 7 o'clock and I am thinking of trying something like this:
    Do you guys think that it could work?
  • 19wrx
  • peter_zxzx
    I would ajust the left side up or the right side down.
    should look like this:
    http://i170.photobucket.com/albums/u...cture2copy.jpg
  • Varty Yo
    What adjustment should i do to help this out.
  • niZmO_Man
    The low side horizontal should be level with each other.
  • Varty Yo
    Well i raised the pass beam up a bit there isnt much more i can do. Still seems off to me. I cant get rid of the 2nd step.
  • Varty Yo
    Lol i hate your aviatar man! I feel like im being mocked... jk.
    Ok ill drop the passenger side i was in a hurry tonight trying to see if the rotation was better
