Retrofitted: 2008 Chevrolet Silverado Duramax "DirtyMax" Good Weather/Bad Weather Quad Retro
  • Retrofitted: 2008 Chevrolet Silverado Duramax "DirtyMax" Good Weather/Bad Weather Quad Retro
    By far the most challenging retrofit I have done thus far. The bowls on these headlights are tiny and the headlights are extremely shallow, the rear of the bowl is the rear of the housing so the total distance from the headlight lens to the rear of the housing is around 5-6 inches. To compound the issue these was a thick steel support for the radiator directly behind the headlights and it needed to ground down ....a lot to fit the projectors.
    I could have maybe squeezed in some MH1s without seating them so far back into the housing but I have seen this done on a few other builds and it looks pretty tacky, the projector lens can sit a few millimeters from the headlight lens. I wanted to get the projectors and shourds as flush as possible into then bowls, my buddy prefered the look of the X-lens D2S which is why we went through the trouble of mounting them and their added size relative to the MH1s.
    My buddy lives up in Tahoe and works as Northstar and usually (not these past 2 winters) is confronted with driving in very poor conditions, typically snow and lots of it. With his input we decided to do a quad setup with 1 pair of projectors for "normal" driving and the other will be aimed slightly lower and fitted with 3k bulbs for "bad weather." The 3K bulbs are not installed yet.
    His truck is fitted with some Rigid Industries lights. In his fogs he has Dually D2s in "spot" and "driving" there is also a pair of Dually D2s in "flood" for reversing. I have a couple pairs of Duallys in my possession and really wasn't too impressed by them, the Dually D2s really are a huge improvement, especially when you utilize them in a combo like he did for his fogs. His truck has come a long way since it's days with HID bulbs in the low beam and fog bowls, lol.
    Build Includes:
    Quad MD2S projectors (1 pair for normal driving and 1 for bad weather, bad weather has it's own switch)
    Morimoto amber xb halos (wired to an auxiliary switch in the cab)
    Morimoto 5five DSP
    DDM Ultra 5500k bulbs
    Gatling Gun Shrouds
    2 HD relays
    A lot of swearing
    Happy this retrofit it over,
    Evan
    Notice the Rigids by his hitch, those Duallys were replaced with Dually D2s
    Stock
    Before, Fog DRL
    I purchased a pair of Depo headlights as his oem units were a little weathered and I Depo uses butyl instead of permaseal
    First things first, amber is OUT!
    Components
    Long way to go
    Hole v1 top, hole v2 bottom, final hole ended up being even larger
    Getting there
    lol
    A lot of shroud trimming as well, the rearward taper of these were tricky to cut as well.
    White demon eye painted
    I wanted to clean up that white overspray
    White internals and black lens holder
    Reassembled
    White demon eye
    Some thin wire was used for mounting the xb LED rings, it was the only way to mount them with this projector and shroud combo.
    Wire snipped and tucked. Shrouds were repainted before final install
    Showing the rearward-tilt of the halos
    Amber halos
    Housing reassembled
    Projector mounting depth
    Such little bowls
    Late nights
    More grinding, dog trolling.
    In the end we ended up taking about x2 as much material out to clear the projectors
    Getting there
    Working on rotation
    So SICK!!
    Amber Halos. Signal/DRL bulbs are stock but will be replaced with LED units in the future.
    Hard to get a good photo with such a large truck
    Buddy was in a time crunch to get back up the mountain so all my photos of the final build are mediocre.
    Bloody Hell, D2s pack a punch
    Dually D2s
    Amber works much better on big trucks IMO
    Demon Eyes
    I love the way the square MD2S lenses complement the Rigids
    Hell yea man! That looks awesome! Even though the truck is so high his cutoff looks like it will be sitting on the roof of a normal truck. Looks good, nice work.
      Still blinding the world
      Originally posted by nine44
      350 wit da wrist boy?
        Great work. How did you manage to paint the solenoid and the shield? Did you take apart the projectors? If so, how did you do it?
        sent from c6903
          So refreshing to see an awesome build on a bad azz truck!
          '04 Silverado 2500HD CCSB
          Awaiting a Proper HID retrofit (RX350)
          '00 Corvette 6spd; FBO LQ9, FX-R 3.0 on 50w
          '94 Camaro LQ4/4L80e Swap; WR
          '93 W/T 1500 RCLB LQ4/4L80e Swap; Sealed 6
            Care to elaborate? The Rigids are used only in high-beam type situations, keep in mind he lives in Tahoe where there are not street lights everywhere.
            sent from c6903
            I removed the lens, filled the bowl with a microfiber towel, and used some painters tape to seal the back of the shield and front of the bowl. I also taped off the solenoid input terminal before painting the front side of the shield and solenoid white.
              Totally, his truck is well-sorted with tasteful and functional upgrades. I have a pair of tails I am going to cut open and paint for him, much like I did for mine of my wagon. Given his geographical location and weather he typically experiences, his truck is a great test bed for experimenting with adhesives and sealants.
              Evan
                It seems like his cut off is like 5 feet tall. That will still blind no? UnlessIit drops in a distance?
                And the fogs also blind really bad with HIDs and raised
                  I set his height adjustment before he left and only if he is right up on someone will his lights blind someone, it comes with the territory of having a lifted truck. This light setup is about as "courteous" as it can be for the height.
                  Rigids will blind at any height.
                    Yeah that'swhat sucks aabout a rraisedtruck. No matter what your going to blind. Looks better tthough! Lol
                      wow much be nice to stand up and be at head light level like that lol
                      head lights came out perfect! I love amber on trucks like this.
                        Especially when you are 6'8" like myself!
                        I will be the first to delete amber on any vehicle but I agree that amber LEDs do fit nicely on burlier trucks, it reminds me of clearance lights on semi trucks.
                          Great work bro, looks awesome. I like the quad projector set up, are all four projectors on all the time when on low beam?
                            Another great retro. Always thought square quads would suite this car well!!!
                            I love the pic of the dog looking at you from under the front axle as you grind the front end. Lol.
                            Probably thinking, "What is this madman doing?" Haha
                              mmmmmmmmmmm quads!
                              Looks good buddy!
