2010 Nissan Note + Hella 3 gen + Valeo LED
  • 2010 Nissan Note + Hella 3 gen + Valeo LED
    Sketch of how it will look after retrofit.
    Car with halogen heaglight.
    Used parts:
    Projector: Hella 3 gen;
    Bulb: Osram D2S 66040 4300K;
    Ballast: Matsushita 3 gen;
    Two LED modues from Peugeot 508 with controller.
    Led in park mode:
    Begin
    Cut led plate and glue on thermal grease two radiators.
    Back of led plate
    Fitting in headlights mask (painted by Motip Acryl Autolack). Park mode:
    Light off:
    LED driver placed on bottom of headlight:
    Headlight body
    All connectors are default + new socket 2 pins: battery+ (hid ballast) and ignition+ (led driver)
    External view:
    Place for hid ballast:
    Wires in internal headlight:
    Projector
    Modding reflector:
    Mounting projector in reflector:
    Slipway for alignment projector:
    Halogen reflector light:
    Projector (base reflector will be painted silver matt spray)
    Projector light:
    Comparison of the intensity:
    HID Bulb after work:
    Final
    Headlight connectors:
    Two fuses on left and right headlights:
    Light off:
    LED in DRL mode:
    Light result - low beam:
    High beam:
    Youtube:
    Not usual retrofits: TLC 200, FF mk3, Avensis, Prius, Note, Note #2, Swift LED
    i teach english with google translate
    Nice work, but you could have replaced that fresnel lens for a sharp cut off though.
      sharp cutoff is very bad for night driving on crazy russian road - eye strain, fatigue, decreased reaction, a sharp transition from darkness to light.
      with soft cutoff abroad can leveling up to 0,5% without consequences for oncoming drivers.
        The LED modules look factory in those headlights. Good work!
          You sir are a Master .. good job
            very very nicely done!
              Very nice work. I especially like the alignment fixture.
              +rep
                nice work!
                  very slick!
                  2012 Ford Fusion - halogen awaiting retrofit
