honda odyssey quad retrofit
  • honda odyssey quad retrofit
    Hi everyone, i've been working on my wife odyssey for the past days in a quad retrofit that i want to share with you, nothing expectacular but it could give an idea for those who want to put bigger projectors in their headlights, i used TL bix, one of the biggest projectors and Pencil beams LS 460 high beam halogen projectors, even bigger than the TLs. What i did was cut the whole back of the headlight housing, made a "floor" out of 16 ga aluminum sheet and made a box out of thinner metal sheet to encase the projectors, originally this was just for looks as the the TLs alone are enough, but the look of a wide headlight with just a projector on the middle and all these empty space on the sides was bothering me, but let me tell you, if the TLs alone works fine, with the pencil beam the lighting is impresive, here some pics
    Back of the housing
    Metal "floor"
    mocking
    final housing
    Ballast
    final "product"
    sorry for the quality of the pics but this was with an old Bberry phone, hope this can give an idea for someone who need it
      excellent work! so when you gonna drop some projectors in the fog lights and make it a Hexa projector setup?
        Neat idea for mounting.
        Output shots?
        Anthony
        2011 Ford Fiesta SES Hatchback
        2008 Wrangler Unlimited FX-R Retrofit
        2011 Fiesta Retrofit Number 2
          enough destruction for now
            Output shots?
            thanks, for output shot my crap camera doesnt distinguish between TLs + CBI and a candle, on wall shots you almost can't see the high beams, but down the road they give a nice hot spot right in the middle of the TL beam, and the throw of these high beams is amazing
              Killer retro dude would love to see output shots. Also did you put a shroud on them?
                Nice work. From the pictures, my guess is you can make yaw and roll alignments by adjusting the mounting screws on the custom "floor". But since the front goes through that carbon fiber patterned plate, how does pitch alignment work? (i.e. how do you adjust how much the beam points up or down looking down the road during alignment)
                  the shrouds are only thin sheet metal with with the opening for the lenses and wraped in carbon fiber , they look better this way and block the light from the back of the projectors
                    Any shots of how you closed up and sealed the back of the housings?
                    Originally posted by cthunder
                      Looks good! Wow you made it seem easy lol. It almost does look like an Acura in that one pic.
                        as the "floor" was perfectly level i didn't have to do any adjustment for my cut offs to get level, for horizontal adjust( left to right) adding washers between the L bracket and the projectors did the trick, for up and down adjustment i used a large bolt between the back of the housing and one of the factory holes on the projectors an using an U washer, the kind that comes when you buy it cheap speakers, only 2 or 3 turns of the bolt give me a very wide range of adjustment, the high beam was fixed the same way but it doesnt have up or down adjustment,it its pointed dead straight and start where the low beam ends, and the "shroud" is divided in two parts, the shroud on the high beam its fixed to the housing, the one for the TLs its fixes to the flat sides that the TL has on the front so the shroud move with the projector, because everything is black or CF you cant see the gaps between the shrouds, you have to put your face righ in front of the headlight to notice any gap or inperfection on the shrouds
                          in the pics where you can see the ballast you can see that i used a thin sheet metal and using a 3" tool (dont know how its called)and a drill i made a hole for the ballast and used self drill screws to atach the back panel, also in that pic you can see the center bolt that is used for up and down adjustment,all the unions between the metal are sealed with clear silicone, and between the metal box and the oem plastic housing i use the spray foam in a can that you can buy on a hardware store and then cut it so it look flat on all sides, also i added weather strip foam between the back panel end the box, everything its sealed except the grommet where the cables goes and a little hole i left on purpose for breathing
                            I may have to borrow that idea since I had to hack away a good size portion of the back of my housings to fit the quad setup.
                              thats the purpose of this thread
