Nissan Note + Bosch AL + Hella LED
  • Nissan Note + Bosch AL + Hella LED
    Sketch of how it will look after retrofit.
    Car with halogen lens.
    Used parts:
    Projector: Bosch AL;
    Bulb: Philips D1S 85410 4300K;
    Ballast: Hella 4.1;
    Two LED strip from VW Tiguan with controller.
    I use two old headlights with broken glass - use 100W bulbs.
    Do not use 100W bulb in oem halogen lights!
    Modding reflector:
    Mounting projector in reflector:
    Ballast on headlight body. Warning label - 74533-33010.
    Replace parking light by turn signal bulb.
    Full sheme:
    New connector for many wires:
    Wires internal headlight:
    Body of headlight:
    Back cap - OEM
    I make label for legalization hid
    Not usual retrofits: TLC 200, FF mk3, Avensis, Prius, Note, Note #2, Swift LED
    i teach english with google translate
    Cut default LED plate
    New body for LED plate
    Mark LEDs on mask
    Back side mask with wires
    DRL/Parking module:
    Photo in parking mode:
    I replace turn signal by clear bulb and make additional high beam
    Body sealant:
    After assembly
    Place for DRL Controller:
    Left headlight:
    Right headlight:
    Final:
    LED in parking mode:
    Turnin signal just created for a new place
    Light result:
    Intensivity comparison:
      Looks great! How well does that extra high beam perform?
      And I love Bosch/Al projectors (E46s)!
      ** Please use the reputation system by clicking the on a helpful post **
        I made this only for signaling when led in drl mode because hid blinking is bad for bulbs and ballasts.
          Good work! I really like the little LED pods.
          2014 Dodge Charger R/T Awd
            Excellent work! I love the connectors, wiring, and LEDs all together like that, very nicely done.
              Fantastic Job!!!
                i love when these comparisons are made from halogen to HID projector, really shows the difference.
                  Amazing job - once again! And a good choice of projectors.
                    very nice. I thought at first you were going to put LS460s in there.
                    "You can take an average picture of an extraordinary thing or you can take an extraordinary picture of an average thing"
                      Thanks for all! See my video how to working light:
                        Nice video!
                          I love the manual adjustment. I wish I had that
                            Yeah, if I ever get around to doing another retrofit I'm going to try and do some sort of adjustable leveling.
                              Great job. I love the additional highbeam. How does the turn signal perform in the new location?
