That_guy's Durango FX-R Retrofit
  • That_guy's Durango FX-R Retrofit
    Links to other posts in thread:
    Version 2 (OEM Style Housings... Current):
    Starting to cut up the housing
    Brackets
    Test fitting shroud and lens
    Test fitting and installing on vehicle
    Finished
    Some Wall Shots
    More Output Shots
    Somewhat Distance Output Shots (different thread)
    Matsushita Ballast Startup Video
    Distance Ouput Shots
    Version 1 (Aftermarket 1pc Housings... got smashed by a dumb b*tch that ran a red light):
    Projectors tuned.
    Some pictures of the housings I'm working with.
    Housing tear down and projector test fitting.
    Installed and working. Just minor fettling to do.
    Output shots.
    Driving video. (Youtube)
    Taking care of the projectors:
    Ok, I have a pair of value FX-Rs that I need to get tuned correctly. As far as I can tell there isn't any physical damage to the lenses, sheilds, or bowls, so I think it should just be a matter of adjustments, but I've never done this before so I have no idea where to even start here. I'm not going for a perfect colorful cutoff or anything here, I just want to get them to the point where I'm getting a good usable light output.
    These pictures were taken with cheap ebay bulbs in the projectors that I bought for testing. They were seated fine and didn't look to be out of alignment. I'm sure they're not perfect, but I don't think they're causing any of these issues other than an off center hotspot. I do have some morimoto bulbs I bought from a member here on the way.
    Here's the first projector. It doesn't look too bad, maybe just some tweaking of the shield?
    Second projector. This one seems to have some bigger issues going on.
    Thanks.
    2014 Dodge Charger R/T Awd
    Yikes. Have you taken them apart yet to see what the shields look like? It almost looks like the high beams are partially engaged.
    05 300C - 15 Taurus SHO
      I'm actually doing that right now. Although I do think the eBay bulbs may be some of the issue at the moment too. I used a square to straighten out the capsules some and the first projector looks a lot better now although the high beam of it does seem weird to me.
      Edit
      I think you hot the nail on the head with the second one. It appears that the shield isn't going back up as far as it should be and it leaving a good bit of the high be exposed. Its high be looks identical to the first ones. I'm going to take it apart right now.
        OK, how do I go about raising the shield up more? It doesn't look like there is any room for up/down adjustment because of the locating pegs on the shield assembly and the shield being at its highest point of its travel. Would spacing it closer to the lens or bowl work?
          In for updates.
            There are 2 finger taps on the foreground limeter that the sheild is resting on, bend it up and you will raise the shield.
            FEEDBACK THREAD
            00-03 Nissan Maxima HID Retrofit
            6th gen AV6 FX35 Retrofit
            Chassis and Suspension
            2000 Sunlit Sand Maxima SE 5Spd.
              This is why you don't buy value projectors.
              Also, get some real bulbs. My FX-R (NOT VALUE) went all whack when I used anything other than Phillips
                Thanks a bunch. I bent those up some and now it sits perfectly. Even got a nice deep blue purple and cyan color band too.
                This is the second projector that was really bad to start. About 20 minutes of tweaking and I've got this.
                This picture is just a zoomed in one from my phone.
                I don't have a ton of money to throw into things so I figured I'd buy the half price ones and make them work. As you can see its turning out pretty well so far. It's a good project and learning experience too. And I will get some OEM bulbs eventually I just don't have the budget for that at the moment.
                  The high beam looks perfect
                  FXR 3.0, Osram 66240, morimoto 5five ballasts
                  Matchbox projectors for hi beam, 35w 4300k
                  Is300 fogs, 100w halogens
                  Originally posted by phantom240
                  Having spent a good many days helping my friend with his '85 300SDL, I can say that it takes balls of steel, an anus of concrete, and infinite patience to bring one of these Deutschland Demons back to life.
                    Honestly, your tweaks look almost spot on for what you were wanting. It gets to a point where you start messing with trying to get it perfect and it starts going down hill. Also, if spacing is the problem, if you get one fixed, look at the distance and replicate it on the 2nd. Should save you a ton of time. Also, the bulbs could be making the difference from them being perfect with the exact tweaking you have done.
                      OK, I was just wondering since the pics in jvx's comparison is different, but his are probably an older version.
                      Yeah, I'm not going to mess with them anymore since I'd probably just make them worse like you said. I'm really happy with how they turned out, especially since this is the first time I've messed with the inside of a projector. The hour or so of time I spent messing with them seems like it was well worth the $80 savings to me
                        Looks great now!
                          Are you going to try to color mod them?
                            Wow, the beam/cut off looks great..
                            -Kyle
                            Working On My 1st Headlight Retrofit (E46 + H3 Mini Bosch) -> 96' Infiniti G20
                              I can't wait to get my FXRs installed as well :-)
                              these pics make me itch!
