So a bit of background first. I never planned to own a Prius but my parents bought a new car and wanted to get rid of theirs, so opportunity presented itself. I decided to put (most of) my aesthetic objections aside and let the excellent reliability, MPG and relaxed driving position guide my choice. But one objection I could not overcome... the stock halogen reflector headlights which had faded horribly over time (as on most Priuses of this generation). I'm a sucker for projector headlights with a colorful cutoff, reflector headlights just don't work for me. So my only solution was to do a retrofit.
Since this an older Prius I did not want to go all out and spend more than €1000, it had to be an economical solution but without compromising on the quality (I'm also a sucker for quality
Also note that I'm in Europe so not all options are available that you'd normally consider in the US.
This was what I bought:
- A pair of new headlights (~ €200)
- Generic Hella G5 D2s projectors (~ €50)
- Hylux A2088 35W ballasts (~ €60)
- Pair of AMP to D2S connectors ( ~ €10)
- Morimoto MotoControl Bi-Xenon: H4/9003 wire harness (~ €50)
- Osram Xenarc Classic D2S 66240CLC (~ €60)
Grand total: ~ €430 and with some other small stuff like sealant and shipping it ended being close to €500.
These are the projectors which I think are Mjni D2S 4.0 clones:
So first things first, opening the stock headlights was easy. I used a heatgun and patience since they were too large to go in the oven:
After removing the H4 headlight cap and the trim pieces I could fit the projector in there.
To tighten the lock nut ring I had to use the dremel to remove some of the H4 mounting pieces
And with the shroud attached using JB Kwik weld. I was quite happy that the shroud fitted perfectly without having to use a dremel.
For a while I considered getting OEM ballasts since these would fit perfectly to the bottom of the headlight, but they were too expensive and only compatible with D4S lights.
Therefore I went with Hylux ballasts which coincidentally had dimensions such that I could use the pre-existing screw-holes
The igniter was attached using 3M VHB.
I test fired the headlights and was happy to see this very colorful dipped cut-off:
I sealed the headlights back up and turned to the least pleasurable part of installing the H4 bi-xenon wiring harness.
I found a spot for the relay next to the inverter, ground for the passenger side headlight was taken from the horn, and a new ground point for the driver side had to be created below the headlight.
Then comes the moment you put your headlights back in the car, hold your breath and turn them on
The step has a kind of dip which takes some getting used to but prevents blinding of opposing traffic.
There is some bowing on the sides but overall for the price I'm more than happy! High beams are amazing too.
On the car:
Finished! I'd never call the Prius a beautiful car but I think these headlights make at least somewhat more acceptable
They have been running for 6 months up until now with no issues whatsoever. Next up will be some LED DRL.
On the car:
