08 GMC Sierra Denali RX350 Retrofit
  • 08 GMC Sierra Denali RX350 Retrofit
    Hi everyone this is my first post I have been a lurker for over a year now. I had my headlights built by fastheadlights. I used TRS tuned RX350 projectors with STI-R clear lens XB35 2.0 ballasts and running D2S Osram Night breakers. Absoluty in love with the output still tweaking with the aiming since my truck has a 1.5 in level kit on it.
    http://i86.photobucket.com/albums/k1...psawdc5rfe.jpg
    Starts
    February 2nd, 2019
    Ends
    February 2nd, 2019
    Hope the link works It would not let my add an image and idk why there is a calendar I was not able to remove it? What a rookie move lol
      Looks good! Yeah HIDP can be funky. I use Imgur and post the BBCode and it embeds just fine.
        Thank you sir just having a hard time aiming them oncoming traffic is no issue but it's the people in front of me.on the highway that are flashing me when I pass them this is my first truck so I'm unsure if this is just how it is with truck retrofits.
          The key on a regular car is to get the right side, the higher side of the cutoff, perfectly horizontal. If you were to park 25 feet from a wall in a perfectly flat area, the higher side of the cutoff should be same distance from the ground as the center of the projector in your headlight. AKA the beam is perfectly straight. On a truck, you might want to lower it a hair. Maybe 2" drop at 25 feet.
            I did try the 2 in drop to start with and my upper cutoff was in the rear view mirrors of cars in front of me lol I got it down to the point where it's in there side mirrors without completely killing my distance vision. I think I'm going to remove my frontflevel kit and see if I can gain back some distance lighting. Currently the center of my projector sits at 41in so at 25 feet I have the lower step set at 35in. Just wish I could get some more distance only improvment from.my stockers is width and brightness but I really wanted distance out of this project
              That's the bad part about having a high truck, sadly. And even worse for us in lowered sports cars because we have to deal with you :P You'll have to find the ideal balance because blinding will happen no matter what, just have to minimize it without killing your own visibility.
                i think I have found the sweet spot but anything lower than an accord there's nothing I can do for them. I am going to pull my level kit out I didn't think it was going to be an issue so I guess I will see I have stock size tires and suspension just the 1.5 inch spacer in the front.
