TRS Hella EvoX-R BMW E46 Retrofit
  • TRS Hella EvoX-R BMW E46 Retrofit
    Hello,
    I hereby welcome myself to this forum! Been lurking and drooling for quite a while, though.
    I finally did a retrofit myself, replacing the burnt ZKW projectors in my E46. God damn those things were unsafe. Halogens were outputting way more than them... It's getting dark at nights now, so I did it just in time.
    I bought the retro-quik EvoX-R kit from TRS. Bulbs are a no-name brand. Thinking about getting some Philips or Osram bulbs, but as per now I'm happy with these bulbs.
    I'll cut straight to the pictures:
    Cutoff:
    High beams (xenon + halogens)
    And of course, a flicker-pic:
    Looks pretty much like OEM:
    Looks cool, Crazy color. OEM look FTW.
      I hope you kept the ZKW lenses though, those clear lenses might as well be gold lol. FANTASTIC output to, jealous!
      2005 Dodge Magnum R/T
        Originally posted by Tommy88 View Post
        High beams (xenon + halos)
        Looks good.
        For a brief moment, I thought it was odd that the high beam was a combination of the EvoX-R's high beam mode and some angel eye "halo" (or possibly the oem angel eye)... what kind of angel eye could possibly contribute to a high beam output worthy to be used alongside the e55r's high beam...
        Until I realized you meant "halo"-gens.
          Looks good.
          Ohh, now I get it. I thought he meant highs + halo rings too. Seemed weird to me too that halos could contribute to highs
            man!!!! that evoxr's high beam is killer! maybe i should've did those with mine instead of TLr's. but yes OEM look FTW. was it pretty simple to do?
              Nice colorful cutoff!
                I suppose in a few years it may be economically feasible for laser based high beams to have small enough frontal footprint to go around a low beam lens. So you can create a ring that emits high beam laser. (I realize beam dispersion isn't quite ideal with the current laser technology to be in that configuration, but that may change)
                  I think anything is possible, even the unimaginable to us right now, with so much advancement in lighting tech such as lasers, plasma, etc.... Good example is how led made lighting applications possible in confined spaces, otherwise deemed impossible.
                    Loving it! Although it does suck that I had to glue the shroud to the projector... Not going to be easy disassembling (if needed).
                    Yes I did. Actually tried setting some paper on fire with it, brought back to my younger years, playing with magnifying glasses.
                    Looks good.
                    Err, my bad. Corrected it now! Would be awesome angel eyes, though...
                    Yes, it's amazing at night. I have noticed one side being a bit brighter, but I guess that's because one bulbs only has 2-3 hours of burn time so far?
                    It was more or less a walk in the park. Used original screw holes. Had to dremel a bit to make room for the solenoid, and cut out space on the flat side of the shrouds...
                      Really nice. I did my E46 with Mini H1s (from normal Halogen) but I'm planning on going OEM / EvoX-R.
                      ! Check out my Ride !
                        Nope, it's because you're using cheap China bulbs. If you look at the first picture, you have no hotspot under the cutoff on the driver's side, which typically means bulb seating issue or that the bulb is crooked (i.e. not exactly 90 degrees perpendicular to the bulb base). The passenger side looks much better, as there is a hotspot, but it's a little low and to the right, so that bulb is probably not quite right, either.
                        Get a pair of OEM bulbs and things will be better.
                        Good job though, it looks great!
                        My retrofits
                          Hey, I just bought a 325ci 2004. I have Hella EvoX-R projectors with 5Five ballasts. I was wondering if it was a simple swap with the stock projectors or if you had to use the dremel a little. If so, do you have pictures of where and how complicated it was to do?
                          Thanks
                            Great output
                              Damn those look great!!
                              Here’s what they look like with CBI bulbs (EVOX-R in my Fusion)
                              2017 Ford F150 3.5 Ecoboost
