2.5 inch fx-r 4300k RHD
  • 2.5 inch fx-r 4300k RHD
    just completed one headlight, thought il share some photos.
    and yes there right hand drive, i live in Australia!!
    Great color & Nice shots!. Btw which bulb do you use?. It looks like right side cutoff is little bowed. Me also from country with RHD. When using with Philips 85122+ mine cutoff bowed like your's but it gone with Osram Nightbreaker.
    Morimoto FX-R 3.0, Denso Slim, Osram 66240 Nightbreaker, E46-R, 80mm XBled Angel eye
      I cant honestly tell you what setup i have i just brought a kit off mick Australian seller and im over the moon with the clarity and quality of his stuff i would recomend him to any aussie who wants to do a retrofit, considering most people use pnp kits, wankers! and reflectors are a big no no with hids but everyone does it, to solve that i turn my 180watt light bar on them haha!
        Great. I really hate HIDs on halogen reflector. I wish to distroy them with but i can't lol!
          Im glad im not the only one!!!
            It could just be the pictures, but it appears like the hotspot is a tad low. The horizontal "arm" on the right side should be slightly higher, almost half of it above the cutoff. That should reduce foreground and increase distance lighting quite a bit.
              Also its not mounted in the car its sitting on the ute fold down tray for testing and for some photos hehe !
                Ok. But the relative position of the hotspot to the cutoff, which seem a bit low, might be affected by where it sits only if something is tugging the D2S bulb's end. Otherwise, it should be the same.
                  Nice! Could use a slight tweaking but still very nice!
                    The bulbs are CN light from memory I don't think you bought Osrams. I would have to check that. lol With the FX Rs sometimes you need to shave a little out where the bulb sits to get them 100% but it's actually easier to file down a little of the bulb holder on the bulb if it does touch. I personally don't think it's worth touching though. The only tweak you would need to do is just move he bulb a little like Satrya said.
                    A lot of people on this forum get more excited about output on a wall then the true outputs of the projectors. lol
                      Did you make replacement lenses? (assuming these are fitted to the car in your username)
                        Who are you talking to mad ? Have you had any trouble with the cops with ur falcon ?
                          No Paul there going in a VX with clear lenses.
                            He was referring to your username thinking they where going in the VN which has defused lenses.
                              Yep, as Mick said.
                              Haven't had any trouble yet.
                              Been through a few booze buses too.
