No color in my cutoff
  • No color in my cutoff
    What is going on with my cutoff? Why is there no color?
      There is nothing "wrong" per say. Your cutoffs are exactly as they were designed.
      The color band along the cutoff appears when the shield and/or projector lens is manually adjusted and spaced.
      Did you do any of this prior to the retrofit?
        Yes, I replaced my frensel lens for the tsx clear lens and brand new cbis. I'm running my 4gen TL OEM projectors.
        I did no spacing or anything just swapped Len's and bulb.
          Usually clear lenses require spacing.
            What do you recommend for oem TLs as far as spacing? Spacers, washers, I asked the question before I got them but no one responded.
              I've never modified TLs so I don't know. Play with it. Move it around by hand. See what it needs. That's how I figured out tuning on my MR2 Koito projectors.
                Thanks will do.
                  Does pushing the cutoff shield toward the bulb give more color? Or is it the opposite?
                      I know this thread is a few months old, but did you ever figure out how to do the spacing to get more color in your cutoff? I know that a few of the Accord guys who've done the 4G TL retrofit used a handful of #8 washers on the bottom mounting pins between the lens holder and the bowl. It takes a bit of trial and error as each projector is different and requires a different number of spacers to achieve the same effect.
                      This guy had to use 2 on each bottom pin on one projector, but 5 on the other to match the first one:
                      https://www.driveaccord.net/forums/1...r-mod-how.html
                      Not only does the spacing add more color to the cutoff, but it makes a noticeable difference in the 'sharpness' of the beam, too. Even with the clear lenses, the output looks blurry along the cutoff without the spacers.
