Koito Bi LED Vs TSX Vs RX350 Vs NHK Hella G5R Vs FXR
  • Koito Bi LED Vs TSX Vs RX350 Vs NHK Hella G5R Vs FXR
    Projectors are in very good state, not used in car / RX350 has perfect bowl /
    Ballast: Hyluxtek 35 W
    Bulp: NHK NBX 5700 K / aprx 80 percent of Osram Cool Blue Intense /
    Lens:
    TSX, FXR,Hella - clear lens
    RX350, Koito - OEM lens
    TSX
    RX350
    FXR
    NHK G5R
    Koito bi LED
    Odoslané z môjho iPhone cez Tapatalk
    Interesting numbers for comparison.
    May I know what is the distance between the projector and the lux meter?
      Nice Comparison. I wonder what a clear lens would do for the Koito LED and RX350. Was the TSX really with a clear lens?
        I will measure the distance later.
        TSX has OEM clear lens. The projector is from first generation of Honda Accord 2004 (Acura TSX), as you can see from cut off). First generation of Honda Accord (2003-2005) had clear lens, facelift (2006-2008) had fresnel lens. Also projector in facelift is little bit different, foreground is with lens holder in one piece. Result is better light distribution in hot spot.
        Clear lens for Koito and RX350 will be apply later, i am waiting for clear lens
          makes sense that all of the OEM projectors (HID and LED) would have the same brightness in the hotspot, and that the aftermarket projectors would be brighter. I'm happy with my G5-Rs
            By my opinion, G5R is best aftermarket projector now.
