Cavyguy's '98 F150 Build
  • Cavyguy's '98 F150 Build
    1998 F150 XLT 4x4
    LS430s
    BajaDesign XL80s mounted behind grill
    (will add as it comes)
    Lights:
    Ended up mounting projectors twice... more solid method second time around.
    Adjusting rotation.
    Passenger sid a little high. (has already been fixed)
    '83 Mustang GT, '98 F150 XLT
    Have A Bear Of A Day
    Damn, that's OEM as ****. Good going, bear!
      Damn you have like 1/3 of the original headlights left! Did you end up sealing up the back?
        Thankies.. few things i could had done better but im extreamly happy with it.. now i need to work on the high beams...
        It got a double take in a drive through by a guy with a bluish Pnp kit...
        cut strait through his beam as well the two cars infront of him.. seen him lean out his window a bit to look back at me and at it ahead of him as i was rounding the corner. Twice... lmao
        yeap.. all sealed up. forgot to take a pic of that, but yeah.
        the bottom quarter cant relly do much with anyways.. very shallow like 2 inch and part of a frame right there behind.. could maybe do something with LED there or something but im likingthe clean simplicity.. more OEM look..
          If I had to do LEDs in that area I'd put a diffused clear lens in front of them, a totally clear lens exposing the LEDs would look out of place IMO
            thoughts exactly..
            for now i likeit just as is though.. not sure ill change anythig on it for a while..
                SC430's are the new hotness.
                  But.... those are LS430s..
                    Oh, Doh! I can't read.
                      Honestly I love how perfectly they fit in the truck. Good stuff!
                        I should spank you fir that
                          I'm going to choose to not derail this thread with speak of spanking.
                              Damn that's sweet looking. A++
                              '04 Silverado 2500HD CCSB
                              Awaiting a Proper HID retrofit (RX350)
                              '00 Corvette 6spd; FBO LQ9, FX-R 3.0 on 50w
                              '94 Camaro LQ4/4L80e Swap; WR
                              '93 W/T 1500 RCLB LQ4/4L80e Swap; Sealed 6
