Chrysler 300 LED DRL project
  • Chrysler 300 LED DRL project
    OK so I've always loved the Audi style DRL and when I bought my 300 last August I wanted to make her mine.
    So I bought some Cree LEDs and this is what I've built.
    I bought some thin plexiglass and cut it with a exacto knife. the width is just under 4mm.
    I then used automotive foam tape.
    Wired them all together.
    So now the hard part is to separate the headlight lens...I'll post some pics when I start THAT project.
    That looks pretty good. Are you leaving the wiring and such exposed? How do plan to mount it, will it sit on a lip inside of the housing?
      Clever way to align the led, and it looks really good.
        I second the clever alignment method. I definitely plan to steal this method and use it on some of my projects.
          I might steal this method also. By the way, has anyone used white Cree P4 LEDs for DRLs? Are those LEDs bright enough to be clearly seen during day time?
            Thanks! No I won't leave the wire exposed. I'm going to make a backing made out of aluminum. It's easy to bend and it will be chrome.
              Since you are going to use aluminum as backing, I would suggest you put some thermal transfer pad between the LED and the aluminum, which allow you to use the backing as heatsink for the LED, and they prevent shorting the circuit too.
                Damn I wish I can do that.. .how easy are these to wire up?>
                2001 CCS (Euro Conversion)
                FX-R DDM-50W DL50 R8-LEDs
                2K4 Mercury Monterey FX-R Retro
                2K1 CCS (Euro Conversion) FX-R Retro
                FOG Comparison: Micro DE, Blazer, Bosch Mini
                HELLA MICRO DE Halogen to HID GUIDE
                  For me it was easy. It all depends if you have patience to work with small wires
                    Woah man, that's brilliant! Simply brilliant! (literally haha)
                      Thanks
                      I made a time lapse of the build.
                      http://www.youtube.com/watch?v=cCoJUNrvCR0
                        I can say there going to be many peoples steal the idea..... at least I will.
                          Originally posted by Madme89 View Post
                          Thanks
                          Nice!!! effin brilliant!!!
                            Update
                            Finished the LED build.
                            Next step is to wire them.
                              Very clean build my friend.
                              Silver/Black 01 Lexus GS300.
