hey guys, I've been working on a RX330 NON-AFS retrofit for my 96 Integra, I have the Projectors, Morimoto 55w Ballast, the Morimoto Harness, 5k Bulbs, and Clear Lenses.
I went to test out everything to make sure it worked fine before I popped open the headlights to install the new inner frame I've been working on, but when I tested it out, I connected everything besides the ballast for the driver side, I noticed that when I turn my headlights on, the bulb/projectors ignite for half a second before they shut off, I believe that the harness isn't securely connected to the positive side well, but it would still have a connecting current, because it was in full contact of the post.
Is it also possible that the bulb isn't fully secured in to the ballast, I don't want to break anything yet, so I didn't put to much force on the bulb when putting it in the ballast. So any suggestions will be nice. Thanks!
I will make a video soon to show what I'm talking about.
