Quad Bi Xenon I need your help Guys.
  • Quad Bi Xenon I need your help Guys.
    Hello guys
    My Car is a 2018 KIA Cadenza premium with OEM D3S Bulb in LOW BEAM, 9005 Halogin Bulb in High BEAM, Turn Signal & LED DRL.
    One cable feed the hole headlights.
    I am in the middle of a process to install a low beam & high beam projector.
    (low beam Q5 projector ) And ( high beam Hella F1 projector ).
    link for 2020 AES Kingkong 3" HID Q5 Projector Lens :
    https://www.aliexpress.com/item/32910899717.html?spm=a2g0o.cart.0.0.575e3c00K9Q9nz &mp=1
    link for AES Kingkong F1 Hella 5 Bi-xenon Blue Or High Clear Projector Lens :
    https://www.aliexpress.com/item/3282...c00K9Q9nz&mp=1
    I wanna run quad bi xenon on a low beam without mess up the LED DRL & Turn Signal.
    For the high beam mode the Q5 stayed running in low beam while the Hella F1 opened on high beam mode.
    I removed the OEM Ballast (Osram 35W) Because I think I can't modify the adapter cable.
    So I am confused about how to set up the Ballast, Relay harness & Spilt Adapters. What should I buy to complete my setup?
    I have already bought !
    1- 2020 AES Kingkong 3" HID Q5 Projector Lens Hi/Low Beam Bi Projector lens 3.0 inch for (LOW BEAM)
    2- AES Kingkong F1 Hella 5 Bi-xenon Blue Or High Clear Projector Lens 3.0 inch for (High BEAM)
    3- (4 PCS) D2S: PHILIPS 85122 XV2 XTREME VISION for low & high beam.
    My need (I am guessing) :
    1- Quad Bi xenon HD relay & harness
    2- Split cable for the low beam and high beam.
    3- (4 PCS) Digital Ballast ( In my country, we have 45w AOZOOM Digital Ballast with Canbus)
    I need your help guys, plz check the attached pic for more details
    I am sorry for my English
    Pic for more details !
    OEM Headlight Diagram
    My Projector Setup
    OEM Ballast - D3S Bulb - 9005 Bulb -Adapters
    Best regard
    If the OE low beam stays on when you high beam, what I'd do is run the OE ballasts for the Q5, and have a separate circuit (relay harness + ballasts) that triggers off the low beam. You also can put a switch in so you can turn off/on the quad as you like.
    If you choose to go full aftermarket, then yeah you'd need a "quad bi-xenon" setup, if that exists.
    For high beam you should be able to connect the solenoids to the high beam plug/wiring.
    Granted my retrofit was for R32 Skyline which runs off a single H4 plug and splits to projector + high beam reflector, so my thinking may be [is] old school.
      Thanks for your replay, I will update the subject with result after I receive my items.
        I don't believe anyone sells a quad harness. I have a thread describing how I did it for a vehicle with dual filament halogen bulbs (i.e. single bulb for both low and high beams) for the OE setting:
        https://www.hidplanet.com/forums/for...-example-pics=
        Posts 7, 8, and 9 show the progression from setting up a single pair of biXenon to a 3-way switchable quad. You can wire your harness directly to your final goal, but I find going 3 steps like that easier to troubleshoot and describe.
          I'd power the Q5's ballasts with the OEM wiring and run a seperate harness for the F1's ballasts.
          https://www.theretrofitsource.com/qu...KIT?quantity=1
            Interesting. The pictures only show a pair of connectors for feeding the ballast. Is it just a two-pack of the regular wiring harness then?
              Now that I actually read the instructions, it's basically two of their 9006 harnesses plus splitters for the OEM low and high beam connections LOL
              I'm not really a fan of their harnesses anyway, I find the terminals to be rather cheap in quality and prefer wire loom over braid for an OEM look.
                I suppose if that were actually the case, it would still work for the "full time quad" anyway.
                  Thanks Guys for the comment, In the coming weeks I will post for my 2018 KIA Cadenza retrofit (Quad Bi Xenon).
                  regards
                    Something like this wiring scheme should work depending on the number of relay packs you use.
                      Thanks for your time and help.
                      I will try your plan.
                      Thanks
