d1s to 2 wire 55w ballast?
  • d1s to 2 wire 55w ballast?
    Have new projector housings that take D1S bulbs and have 55W ballast. D1S bulb has 3 pins and 55W ballast has 2 wires (+/-) to connect to the bulb. Does anyone know how to connect the 2 wires to the 3 D1S pins? Perhaps a wiring diagram of the 3 D1S pins (1 pin space from other 2) may suffice.
    That cant work, your ballast has an igniter inside or it goes ONLY to a 2 wire input inline igniter, D1S has a 3 wire input integral igniter, you must have a 3 wire input to the D1S bulb, there is no other way.
