Wk1 jeep retrofit questions
  • Wk1 jeep retrofit questions
    2007 jeep GC, mh1 7.0 projectors
    First question, I have an amazon bench tester, plugged in a 9006 pigtail, but cant get the bulb to turn on, for a wall shot to aim match a projector. I have 12v+ at the 9006 connector, and tried 3 different bulbs.
    Second question is how to pull the reflector bowl from the housing. I feel I would break if I tried harder. There is a little white adapter that sits between housing and reflector, should I pull on that, or on the reflector part?
    Tia
    What ballast? What bench tester? Got a pic of your setup?
    It's usually a ball socket, right? Also would really like pics to give 100% accurate info, but usually you pull hard. Preferably with lots of heat on that ball joint.
      https://flic.kr/p/2ia5TFG
      https://flic.kr/p/2ia9wcL
      Hopefully those pics work
        How is the white adapter attached to the housing? The picture is roo dark in that spot. I've had good experience with a small lever that I used around the ball.
