H4 wiring question
  • H4 wiring question
    I just got Koito Bi-Beam LED form Toyota Fortuner so I will install it to Honda Jazz (Fit).
    The original bulb type is H4 and I don't want to use h4 to HID adapter, I worry about quality of it. Then I want to use relay to control low and high beam as picture below
    Is it possible to use this circuit? or do I have to add diode between original low beam and 87 of relay to avoid reverse circuit
    I don't think LED projectors would draw that much current to warrant a relay setup. Unless there's some weird electrical funkery going on.
    I put (HID setup) a diode at the plug going high -> low so both circuits are energised when high beam is used. Wired high directly into projector shield and low going to trigger the relay.
      At that time I just worry if I use high beam for long time(~5 mins), the diode will be fired up. But now I use diode as your reply and everything work fine.
      Thank you
