Hella E55 replacing with EVOX-R 2.0, Hella OEM ignition fitting issue
  • Hella E55 replacing with EVOX-R 2.0, Hella OEM ignition fitting issue
    Hi Folks,
    I am planning to chance the OEM E55 to the beast. Car is Vauxhall Vectra C 2004. Bolt pattern is the same as Evo 2.0. Here is only one isue. The end of the OEM projector has special design to fit the hella bulb ignition (starter). EVO 2.0 and even 1.0 has no this design. We prefer 2.0. It has ring holder. I am unable to hold the starter to the bulbs only. It has four small clips that fit for only the OEM style projector.
    This is a very common projector. Can you help me with same advice how can I solve this issue. I saw d2s to d2s adapters but it can't fit in the ignition correctly. There is nothing that will keep the d2s bulb adapter in the hella ignition. I don't wan to do same crappy work with glue..etc.
    OEM ignition like this one:
    https://archiwum.allegro.pl/oferta/s...130018715.html
    I think there should be a good easy solution. This is a really common projector retrofit type. Thank you for your helps in advance!
