Hey y'all. I'm going a super cheap retrofit on my 2001 MR2 Spyder. I have a relay harness, 9003/h4 HID kit, and projectors. The HID kit has a xenon bulb and a halogen bulb; i removed the halogen b/c i'm planning on having the xenon powered for hi/lo beam and letting the projector housing solenoid shield handle hi beam.
The rub is, when I activate hi beams to remove the shield, they lo beams should turn off by default... I don't want that. My wiring solution is below. The existing relay harness is shown in solid lines and the addition relay is dotted. The intention is to keep the HIDs on with the new relay in hi beam without sending power onto the lo beam wiring. Also I'll be using anti-flicker caps before the ballasts in hopes for a smooth transition between hi and lo beams.
Let me know is theres a better way to do this, or if you have any tips.
