h11 wiring for OEM connector
  • h11 wiring for OEM connector
    Got an H11B HID kit... Which connector/converter/plug is required to make metal pins properly connect with OEM plug?
    plugging metal pins directly to OEM connector works but not permanent solution. Honda Civic 2017 Low Beam
    Welcome to HID Planet! What brand HID kit did you get with just spades and loose wires? It's not clear what I'm even looking at.
      Thanks Halo. I got Hylux ballasts combined with CNlight H11B bulb.
      Sorry, that photo was just for reference. Everything is wired up and working but the spades go into stock/oem harness and it doesn't seem safe (they come out easily). Is there an adapter or solution for this?
        Ah yeah, cut them off and crimp/solder on proper H11 plugs. You can get them on eBay. Spades are definitely not ideal. Or you can upgrade to better bulbs with OEM style connectors.
          Would this work?: https://www.ebay.ca/itm/2x-H8-H9-H11...torefresh=true
            Yep, I don't see why not!
