Hi all,
I have a question on the dual bi-xenon setup but with a twist. My car has single lights, both high and low in the same bulb. I have installed hid bi-xenon projectors which are working just fine. I also have fog lights for which iam thinking of installing bi-xenon projectors. Fog light uses different switch.
Headlights - h4
Fog - h3
The circuit i have is, 2 separate relay harnesses one for headlights and one for fogs. Headlights are easy, just use the h4 socket to relay and high/low works. I want the fog to turn on only when i turn on the fog switch, so + and - will come from the stock fog wires to relay and the high will come from the headlight switch(split only the high signal into 2).
Questions,
1. Is that the right setup i need to make
2. With the above setup, when all the lights are off and when i flash the headlights will turn on but will the fog lights turn on as well ?
Headlights - h4
Fog - h3
Questions,
