Install help.Quad Bi Xenon..
  • Install help.Quad Bi Xenon..
    First let me say I suck at electrical.
    Car- 2009 G8
    Gear- Quad Ds2 projector, Two wire harness with relays , 4 High beam splitters ,4 Ballast. (all ordered from TRS)
    Well i have the D2S mounted and about ready to finish. Just stomped on Wiring.
    My car does leave all four lights when highs are selected, Need best install method.
    What i want is maybe all 4 on at once and when hit the highs teh bi-xenon work as supposed. ( dont think ill ever need highs but u know if u have it use it.)
    Option 1- Can i run one harness and use the two splitters? Basically each harness has 2 outs to ballast ,I would install a splitter at each end that would turn on total of 4 splitters. ?
    Option 2- Original lows when in use then all four with or with-out Bi-xenon when highs are hit. ( very tricky wiring.)
    Im looking through this thread to get ideas .. https://www.hidplanet.com/forums/for...-amp-Examples=
    1991 240sx
    SR20Det
    13.7@103
    Always do sober what you said you'd do drunk. That will teach you to keep your mouth shut.
    Looks like i got what i needed here.. Thanks. If yall see any issues with this please let me know. https://www.theretrofitsource.com/me...QuadWiring.pdf
    1991 240sx
    SR20Det
    13.7@103
