Morimoto hids flickering
  • Morimoto hids flickering
    Ok so i did a retrofit. Installed some morimoto projectors and hids with hd relay harness and antiflicker capacitor. My problem is my lights are still flickering. Grounding points all seem to be good. All tightened down.
    But i did notice that the oem connector and relay capacitor connector line up (per tabs) to opposite color wires. Theres a black and white wire oem connector but the relay capacitor wires line up opposite....red on black and Black on white when connected following the tabs on the connector. Can i safely reverse the connection to see if it works...”reverse polarity”. Btw i will be contacting trs tmr but they are closed right now so i figured i ask u fine folks. Appreciate all the help.
    Reverse polarity won't fry a Morimot ballast as far as I know.
      Thanks for the looks. Well i flipped the input from the oem and tad-a its been working great. Thanks
        Great!
          That's good.
