LED strip for blinker and marker light
  • LED strip for blinker and marker light
    I'm going to be using LED strips as my blinkers and marker lights. I would like to use the OEM harness plug to run the blinker and marker light. It's a 3 hole female connector that plugs into this and runs a 3157 bulb. So assume the 3 wires in the harness are for blinker, marker and ground. Is there a way to make the LED strip work as a blinker and marker light? If i use it as a marker light, I'm not sure how i could cut the power so it works as a blinker when needed.*
    Sent from my SM-G930V using Tapatalk
    Diode Dynamics Tail As Turn or exLED TPC, they both do the same thing. I'm installing a pair of TPCs at the moment actually.
    https://www.diodedynamics.com/tail-a...odule-diy.html
    Buyer beware: exLED products are nice but customer service is shitty. Goes for their main office in Korea and their USA division.
    http://www.exledusa.com/exled-electr...air-a-set.html
    https://corsomotion.com/collections/...ules-ver1-pair <---- I think these guys are also exLED USA.
      Awesome, thank you. I'll stick with diode dynamics if they have better service. Your link for diode dynamics doesn't work by the way, but i found the part looking when i searched tail as turn.
        Yeah that was odd, you're right the link doesn't work. https://www.diodedynamics.com/modules/tail-as-turn.html for anyone interested, select the DIY version
