Single Beam to Double Beam Wiring Help
  • Single Beam to Double Beam Wiring Help
    This is my first post here at HIDPlanet.
    I did try to search the forum, but I couldn't find anything, hence decided to post a new topic. Pardon me if this already exists, Mods can move/delete the topic if they please.
    My current car comes with a headlamp that takes a single H4 bulb for both high/low beams. Since this wasn't quite effective for highway drives, I got the newer version of my car's headlights which is a projector setup. This new setup takes H11 (low beam) and H1 (high beam). The headlamp fits perfectly, but there is one issue.
    When I switch from low to high, the low beam in the projector turns OFF. Is there any way I can keep both ON when using the high beam. ??
    Should I use a Relay or a Diode ?? Also a wiring diagram would be helpful.
    Thank you.
    Welcome to HID Planet!
    You'll need a Morimoto Motocontrol H4 harness for that. And for the low beam you can use a 9006 to H11 adapter.
    Or you could modify your headlight relay. It's super ghetto but it works great, been working for 3 years now. I bridged the low and high side of the headlight relay.
      What model/year vehicle? You may not need diodes etc
        Its an Indian car, specifically 2017 Tata Tiago.
        The projector lights is what I'm moving to from the reflector headlights.
        Here's a picture. Don't know how to upload pics here.
        http://images.asianage.com/images/05...mg-preview.jpg
