Delaying HIDís startup
  • Delaying HIDís startup
    Sorry if that was already here but i want to ask if there is any possibilty to delay the startup of my retrofitted headlights , i know i can just turn them off while starting the engine but in case i forget or my girlfriend is driving the car or so.. I tried timed relay module but havent worked so well( china crap, it burned). Anyone knows about oem or similar to oem module for delaying ? Thank for advice
    Timed relay is probably the OE solution short of the computer module having a programmed timer. Perhaps the relay wasn't rated high enough? You may have better luck if you place the timed relay on the signal side of your wiring harness, so that it doesn't have to handle high current flow.
      I actually did that, so it triggered the relay not the ballasts but it was not proper relay i guess, waiting for classic timed relay if that helps but i was searching for some more refined module.
        I found using a cheap ebay relay to trigger a proper relay to handle the high current worked for me.
        But a proper all in one solution as you said is way better if you can find one.
          That looks like an interesting solution
          Haven't seen a post from you for a while
            Heya mate yer tis been while good to see you still here the LED modding forum looks a bit quiet
              Likewise.
              I think the whole webforum has gotten a lot quieter. Supposedly, headlight junkies and other alternatives are the way to go now.
                Likewise. I think the whole webforum has gotten a lot quieter. Supposedly, headlight junkies and other alternatives are the way to go now.
                Then i'd better start a worklog keep the DIY thing alive!
                  Maybe
                  Or perhaps the number of people doing DIY will be like the number of people that know how to start fire with kindling.
                    Buy super slow startup ballasts😜
                      Suppose we take your comment at face value for the sake of argument (I believe you're kidding); ballasts that startup very slow may not necessarily draw less current during its initial startup spike. In fact, some of them may be even worse.
                        Ok I re-write it
                        Buy slow startup, less initial and overall current draw ballasts😬
                        I was just kidding though(this happens when you start spending time on headlight junkies lol)
                          There are ballasts designed for low initial current draw. I know Hylux makes a version specifically to get around that. It's a slow start version with low initial current draw.
                            I eventually bought better 5sec delay relay and i use it to power up the morimoto harness and it works well now. I’m not throwing my gen3’ís away
