So I bought everything required, and thought I was gonna be able to pry open the permasealed lights Heat heat cycles from a heat gun......boy was I wrong. Ended up cutting open the housing.
My question here is, what epoxy do you guys use to seal them back up? Would the plastiweld or waterweld epoxy putty be good enough with silicone over it? It's rated at 300 degrees. Any input would be greatly appreciated, don't wanna have any moisture build up when they are installed on the car.
