'05 Legacy retro
  • '05 Legacy retro
    So I will be getting another Subaru soon, it's been awhile but seeing as how the car came stock with H1's I don't know if I should do bixeons or just keep the highs and just get lows? I'm looking for good brightness but not a total pain in the ass to install the lights in the housing..
    well that's no fun...
    quads perhaps?
      quads perhaps?
      last lights I did I squeezed the FX-R's in a housing
        If you're satisfied with low beam only, i think the Maxima low beam projectors bolt on.
        2005 Legacy GT: Stage 2 + VF52 turbo, RX330 w/custom shield, Nichia DRL
          Ahhh so yeah I'm going to have to do this now.. I finally found a car and I looked under the hood and it has a P-n-p kit looks to be around 6000K
          What projectors have a mount like the FX35?
            I really have no clue, but as the FX-R is based on the FX35, it might be a viable option.
            My retrofits
              Wait 05? Doesn't that have an h7 and use rx330 non afs
              AAAAAAAAAAA
                Correct uses H7
                  Correct uses H7
                  Is it possible to do bi-xenon?
                    You can always replace a low beam only projector with biXenons, provided that the wiring provides the right power for the ballast and solenoid in high beam mode.
                      Yup, and a member here, (greenkouki) wrote a DIY on how to convert them.
                      Originally posted by cthunder
                        Ill probably be doing this to an 07 soon
                        AAAAAAAAAAA
