Problem with FX-R light output
  • Problem with FX-R light output
    Hi guys,
    Iīm currently building a setup for a friendīs Audi A3 8P.
    The FX-Rīs are the model before the actual one, and when finished installing the projector, I connected the headlight to a power source, and had as a result a very crappy cutoff line...like ghosts appearing on it.
    Any clues on what might be causing this?
    Thanks in advance!
    Could be bulb seating issue. Bent bulb. What bulbs u using? Could also be a sheild aligment issue.
      Oh man, definitely check the bulbs and shield. If those don't work make sure the lens is also seated flat, as that can also give a double cutoff.
        How far is the lens from the wall?
          That's look terrible , maybe to close to the wall ??
            Looks like your like 3 feet from the wall, back up
            Originally posted by nine44
            350 wit da wrist boy?
              ^^^ this
                The cutoff looks similar to mine when the bulb was not sitting properly. Reinstalled bulb and made sure the clips are secured and cutoff was back to normal.
                2009 Pontiac Vibe GT (Sold) -- TSX projector -- Osram SVS -- Potted Denso -- TRS Harness
                Currently have 2014 Mazda3 sGT hatchback, too lazy to change pic
                  Thanks everyone. Yes, aprox 3ft from wall...u guys are really eye professionals lol
                  I think bulb is sitting up correctly, double checked that, but will do again.
                    You need to back it up to atleast 12-15' or so.
                    Originally posted by cthunder
                      Even from 3ft it should not look like that, pretty sure nobody's cutoff in here looks like that when they park near a wall .
                      +1 for the bad shield/bulb alingment
