H7C Bulbs
  • gold94corolla
    More clearance = more distance between the end of the bulb and the cutoff shield
  • Fstrsn
    Originally posted by Dave_TDI View Post
    So other than being able to fit into more confined headlamp housings there is no advantages over a conventional h7 hid aftermarket bulb?
    I was half thinking due to being more similar in size to a standard h7 bulb that they might give better alignment or beam pattern...or not lol
    Better, maybe? But still very very far removed from ideal. There is no way to place an HID bulb in a halogen based reflector/projector and have it be ideal. Halogen and HID are two completely different light sources.
  • Dave_TDI
    Originally posted by TRSAndrew View Post
    Our H3C bulbs are shorter physically than the H3 bulbs, the "C" representing a shorter glass capsule. In shallow housings, this is necessary.
  • TRSAndrew
    What exactly are you referring to when you say better clearance in the head light?
  • Dave_TDI
    Originally posted by gold94corolla View Post
    There is no way for them to produce a better beam pattern, only thing it can do it have better clearance in the head light.
    Originally posted by toooosloooow View Post
    http://www.hidplanet.com/forums/show...D-amp-HID-fail
    here's my LOL thread on so-called high end HID projector performance H7RC HID Kits (and LED kits in H11 applications)
    you can draw your own conclusions
    Originally posted by Burzum View Post
    Thanks, I'll have a read of these
  • Burzum
    He won't quit ! lol http://forums.vwvortex.com/showthrea...y-2014-edition
  • toooosloooow
  • gold94corolla
  • Dave_TDI
    started a topic H7C Bulbs
    H7C Bulbs
    I've come across H7C bulbs a few times on the internet but don't know a huge amount about them other than they are aftermarket H7 HID bulbs which are a little bit shorter.
    What I'm wondering is are these bulbs supposed to produce a better beam pattern than the more common H7 hid bulbs as they are closer in size to an original H7 bulb or are they just shorter to fit in tighter headlight housings?
    Thanks
