min. lumen for fogs
  • min. lumen for fogs
    what would you guys think is the lowest lumen count for fogs lights that would still be useable?
    Looking into premade led modules to retrofit, found a couple. One that is almost ideal is only 600 lumen however.
    X5's and XB led fogs wolnt work however for my application. So no need to mention them.
    2000 Mustang Gt-SOLD RX350's Osram, Morimoto 5five ballast
    2006 GSXR-G37 Projector,XbaLed halos,Morimoto 3five,Morimoto 4300k
    2000 Ford Expedition-FX-R1.0s,Morimoto4300k,Morimoto 3five
    Doesn't that also depend on how wide and how far you plan the foglights to cover?
      ^^^ was gonna say, are you looking for a usable foglight ( as in actual inclement weather)? or a driving/aux light thats in the foglight location?
        i don't believe there is a minimum lumen requirement for fog lights.. i believe the foglight requirements are generally pretty lax overall...
          essentialy just for looks, but id rather have some what bright and narrow vs wide and dim.
          Naw, fog lights arent really needed here, just trying to complete the "look"
          right, but seeing as how the XBs are rated at "around 1200" 600 just seems so dismal.
            well if they are just for looks, then anything will work
            otherwise, I'd think that halogen output lumens would be the minimum
              I dont want a candle for output lol. Per Autozone.com an 899 halogen is 754lumen. back to the drawing board.
                halogens are usually around 1600-1900 lumen
                  The fog light requirements in the US aren't really strict so it's pretty fair game. If anything, the restrictions lay in the realm of the bulb used, not the fog fixture the bulb is in.
                    headlights are that, foglights halogen bulbs are usually 30-40w so more like 1000lm
                    US/CA foglights are more like AUX lights really. very few cars have " real" foglights.
                      My fogs are H3 55W/12V... and filled with water.
                      My retrofits
                        I rarely get fog, but when I do, I turn off my main headlights and run my side markers and fogs only and have MUCH better visibility that way. Doing it that way, the fogs have to be bright enough to light up everything that a headlight would.
                          h8 fogs on some European cars are 805 lumen. that being said, their beam pattern is less about foreground and more lighting up the side of the road
