I am very tempted to painted an HID bulb to reduce glare in the meantime before my retrofits. Anyone tried this method? Does painting an HID bulb cause more heat to be trapped, therefore shortening bulb life and oxidizing my headlamps? Any input would greatly be appreciated, thanks!
Painting an HID Bulb to Reduce Glare
If the reasoning behind this is that you have a PnP kit and it creates glare, the only correct solution is to remove said kit and install halogen bulbs until you get your retrofit completed.
Painting lightbulbs has n ever been a good idea, and I honestly can't see anything good come out of this. The bulb is under high pressure, and even fingerprints can cause it to explode, so I dread to think what covering the surface with paint (whichever type) will do for the temperature and pressure inside the bulb. Best case, we're looking at an exploded bulb. Worst case, exploded bulb, a fire and death.
In short: Don't.
My retrofits
This had been attempted multiple times on here and every time there's still glare. Doesn't work
i wouldn't paint the bulb. go back to halogen for the time being till your retro is done. however for reasons you must use your pnp, if you are desperate and need a temporary solution, you are better off masking the areas of the reflector that contributes to glare with black gaffe tape. again, this should only be a temp fix as it may leave residue on the reflector if used for a long period of time. however, if you plan to paint your housing, no worries there.Last edited by pwr2wh8; May 21st, 2014, 09:32 AM.
+1 on the option and its inherent drawbacks mentioned.
The challenge is that the HID bulb's arc generates a different light source shape than the halogen filament.
@OP: If we simplify the HID arc as 2 point sources (it isn't , but it's better to think of it as 2 spots at the extreme ends than a single source in the middle of the arc), where one point generates a beam that is a bit lower than the halogen counterpart, the other point generates a beam that is a bit higher than the halogen counterpart.
The one that is lower won't contribute to glare unless the road is wet, but it won't cover a good distance. The one that is higher generates glare. You may end up having to cover most of the reflector facet in order to remove the offending glare. The rest of the facets will not likely generate sufficient low beam like pattern.
Originally posted by Thepurplekowman View PostBut one question is that will painting an HID cause more heat to be trapped, causing oxidation of the headlamp?
Originally posted by csjoh View PostPainting lightbulbs has n ever been a good idea, and I honestly can't see anything good come out of this. The bulb is under high pressure, and even fingerprints can cause it to explode, so I dread to think what covering the surface with paint (whichever type) will do for the temperature and pressure inside the bulb.
The paint, depending on type, may outgas causing hazing of the reflector. This is simply not a good idea. And, yes, depending on paint type you could cause the bulb to explode inside the headlight causing a great deal of damage.
