2001 BMW 325Ci E46 Quad Xenon
  • 2001 BMW 325Ci E46 Quad Xenon
    So, The RetroFit Lab referred me to come here to ask for questions, as he/they couldn't help me answer my question, so here goes....
    Car: '01 325Ci, aftermarket HIDs. Low beams work completely fine and at full power when the high beam ballasts aren't plugged in. Once you plug in the ballasts for the high beams, the low beams flicker quite a lot and occasionally shut off completely until I turn the lights completely off, wait a second or two, and turn them back on. Only for them to continue flickering and still be at risk for shutting completely off. They flicker at the same times but don't turn off together always, sometimes they do, but it's usually just one or the other. It does flicker in Accessory, but it doesn't seem like it does as badly as it does while driving. (Maybe a few flickers per half mile (While Driving)) Note: If the high beams are engaged, the low beam flicker is seemingly at an all time high.
    Low Beams Ballast : O-NEX
    High Beams Ballast : Unknown, no brand name on it. Only what appears to be a part number
    Could it be that it's a ballast causing this? Possibly a faulty or bad connection? Hopefully a lighting genius can help me figure this out.
    **Also note that the O-NEX ballasts are probably a year or so old (Late Dec. 2012), all of the bulbs are less than 4 months old, along with the High Beam Ballasts**
    My Build Thread
    2001 BMW 325Ci
    OEM BMW Style 71 Double Spoke, Dark Grey Suede Headliner/Shift Boot/E-Brake Boot, Black/White CF Logos,
    Eagle-Eye LED Tail Lights, Shadow Black Front Grilles, Morimoto Mini H1 6.0 Quad Xenon RetroFit 6000K,
    Track Stickers, Clear-Smoked Corner Lights
    have you connected your ballast directly to your battery? do that first as this will show you if your harness is ****ed or your ballast.
    good luck.
      And if the ballasts still respond consistently like your initial test on the car, repeat the test again with the bulbs swapped (from the one that seem to work better to the other one). Then you can be sure which ballasts and bulbs can be trusted.
        good luck.
        I have not tried that, definitely hoping it's not the harness.
        My Build Thread
        2001 BMW 325Ci
          It shouldn't be a problem with the bulbs, because they are all the same bulb temp made by the same manufacturer. It really seems like it would be the ballast or possibly a weak connection between the high beam connector and the ballast connector.
          I appreciate the reply.
          My Build Thread
          2001 BMW 325Ci
            Just because the bulbs are from the same manufacturer and are the same color temp doesn't mean that aren't different. Swapping your bulbs from side to side is a free test. Quality control on aftermarket products is not great. Even a minute difference in the gap between the electrodes will cause a change in resistance making one bulb start different than another.
              I wasn't saying he was wrong, as I am no genius in the lighting field. I just thought that I'd throw it out there.
              I'll be sure to try everything said, I'm pretty sure that it's a flaw in my wiring harness though. The High Beam ballasts don't necessarily "click" into position.
              My Build Thread
              2001 BMW 325Ci
                I'm just helping support his suggestion in swapping the bulbs. It's simply a process of elimination when dealing with problems. Part of the diagnostic. I have some bulb pairs where 1 bulb causes problems with ballasts. Whether it's the mixture of chemicals inside or the wear of the electrodes. I was able to isolate the issue to 1 of the two.
