WTF. I'm so irate about this. Finally fix the yellow lenses problem and now I put the bulbs in and they just keep flicking ever so slightly. WTF is going on? Do I just need to stop using HID and try regular Halogen?
HID Fog Lights keep FLICKING...
What components are you using? Are you using a relay harness? Are you sure the flickering isn't the housing vibrating?
Originally posted by cthunderThe more you mod your car the moodier it gets.Avalon Dual Lens | Rogue LED | Mori 3800K | Mori 3Five | H11 PnP LED
I got the kit online and it's been PERFECT since. Well had to change the lenses to yellow so I can get that output. well the 3k bulbs were flicking so I go to install the 4300k and they flicker. It's not the vibration because they do it when the engine if off too..
How would I go back to halogen?
When you say online, you mean ebay or DDM? Guessing you need a TheRetrofitSource harness
Hers-Sloped TL's, ZKW-R lenses, 85122+, E55-R, fiberglass buckets, Blazer fogs with 3K
Mine- Morimoto Mini H1's, e55 shrouds, Blazer fogs with 3000K
Zuma 125 Mini H1, Gatling Gun 2.0, 90mm & 60mm Amber XBLED halos
https://www.facebook.com/pages/RetroFix
My driver one flashes here and there. Kind of weird because I've checked connections
I notice that mine flicker (they just dim a bit) when I hit a big bump. The grounds are all good and I'm using a morimoto harness. I know for sure that it isn't a problem with my electrical system or anything like that. As long as they keep working I guess it isn't that big of a deal.
2014 Dodge Charger R/T Awd
