Yellow Fog Lights w/ 3000k HID Bulbs turns Alien Green?!?!
  • Yellow Fog Lights w/ 3000k HID Bulbs turns Alien Green?!?!
    I've tried 3 different sets of 3000k HID's and still the same look. So which HID Kevlar temp should I get to actually have a nice yellow output at night? 4300k? 5000k?
    Appreciate the help.
    Originally posted by ATMJDM01 View Post
    [ATTACH=CONFIG]24683[/ATTACH][ATTACH=CONFIG]24684[/ATTACH]
    4300K or 5000K behind yellow lens.
      http://www.hidplanet.com/forums/show...low-ES300-Fogs
        You should get some projects maybe yellow lens es300 with 3k h3cs
          I just had the Fogs installed this morning. Had 3 different sets the shop had and one set was mine (3000k) and it turned out that green lmao.
          So I will go with the 4300k or 5k. Which out of the two do you all think will be a better output for me???
            might be your yellow lens cover if that's a vinyl
              Nope, the actual lenses are yellow.
                You need 4300k bulbs, end of discussion!!!!!!!!!!!!!
                  Appreciate you!!!
                    No problem, 4300k with a yellow cover is the best for foglights IMO.
                      ^^^This.
                      FX-R's with CBI's and ES300 with Mori 4.3k bulbs
                      Originally posted by cthunder
                        Originally posted by Fstrsn View Post
                        ^^^This.
                        Very nice. I ordered my bulbs so I will update with pics when I get them and Install them.
                          I'm not sure I've ever seen someone with 3000k bulbs and actually thought it was a matching pair or enjoyed the color
                          AAAAAAAAAAA
                            the issue is, with the HID bulbs, they use a mult-layer "dichroic" style coating. That's why people recommend a straight yellow filter.
                              Especially since you already have a yellow filter. 3000k bulbs are made using 4300k bulbs anyway.
