Modifying shield?
  • Modifying shield?
    Any idea if this would work or do you think it'd cause too much glare for other drivers? The idea is to cut the shield so it passes light through on the passenger side ditch area. It would also help to light up ditches.
    I would say that having full beam intensity on a reflective sign will just blind you.
    You only want the least amount of light to hit the sign so you can see it.
    Unless you're like some others on this forum who are blind as a bat.
      Lol blind as a bat
        It might be better to place a small piece of semi reflective metal ahead of the shield in that area to create a squirrel finder effect. Brushed metal should be shiny enough.
          ^That's what I would do, it should just be bright enough to illuminate the sign for you to see.
