Hello
Low beams are not working once I connect the OEM high beam to the MLED 2.0 driver. The high beams are permanently on regardless of stalk position. If I disconnect the high beams from the LED driver and connect my stock high beam bulbs or Mini HB LED to the high beam OEM, the low beams and high beams stock / Mini HB work as expected.
The grounds are fine. In fact I redid the battery terminals, new battery and also did the Big 3 wiring. I suspect it is a voltage issue or something I just do not know where to start . Do I need a harness, capacitor, etc...
2005 Acura RSX : Low Beams - H1, High Beams 9005
Any help anyone can offer is really appreciated, I am pulling my hair out with little remaining lol
Thank you.
