75mmx30mm, Clear lens options??
  • 75mmx30mm, Clear lens options??
    I recently purchased some 33mm focus height 3’ Mazda/Sonata clear lenses from trs.
    The beam isn’t focused properly. I can only assume this is because the height is different?
    Would an STI-R with 3mm spacing work properly?
    I also saw some chinese 76x29mm glass lenses on Ali. Would this work better?
    Have your measured your factory lenses for a baseline figure? I'd guess that curvature is important as well.
      I’m not sure how to measure the curvature. What other measurements would I need?
