Halogen projector swap
  • Halogen projector swap
    Hi..
    Im runing h7 xb morimotos. These new projectors take h1 bulbs.. but the merchant added a h7 connector and said it'll work but i cant get them to go all through I'll do a simple mod to the projector opening later. I just put in the projector to see how those clear lenses work out and i ended up in this.. 3inch bixenon projectors are from china. Didn't fit them in headlights.
    Tak
    https://ibb.co/JcDw5VG
      Originally posted by 1splash. View Post
      Hi..
      Do you mean the h7 to h1 adapter can't fit the opening on the back of the headlight housing? I'm not sure what you mean by "can't get them to go all through"
        The H7 bulb base has metal holders around the bulb itself it's hard to get them inside the projector, they block the bulb from going in the projector... The older H7's were just round at rhe bottom.
